Root Help customizing my MIUI lockscreen
Ok so ive got this custom lockscreen:
Chrome Slide LS V2 by ~CocaineMonster on deviantART
How do i get the album art to show up from PowerAmp? The buttons work fine but i just get a blank box instead of the album art.
I decided to try delete MIUI Music from ES File Explorer incase that was causing the problems but I'm even having trouble deleting that.
Thanks
Edit: Not sure this can be done, but if anyone has any ideas?
Ok I've got another customising question
on the standard miui launcher the status bar is transparent but when I go into GoLauncher this happens.. Any idea how to make it transparent?
