Hi everyone,
I purchased a Cyclone Astro+ and have had no problems with it at all, until I was away from home and used my o2 Huawei E173 3G Dongle.
The dongle worked fine, proper 3G connection, the problem now is that any WiFi point I used prior to using the Huawei simply says not in range!
It is strange in that wifi points that I didn't use prior to installing the Huwei work fine, it is only the wifi points that I used prior that say 'Not in Range'.
Details of the Cyclone Astro+:
Android Version: 4.0.3
Baseband Version: 1.1
Kernal Version: 3.0.8+ inet_wl@inetsuperserver #6
Build number: 97F2-D1-H2-H01-2101.20120515
It seems like many are having issues with Wireless connectivity on Android 4.0.3 and the 'Not in Range' Message, so the Huwei 3G dongle may be a red herring.
It looks like only a factory reset will resolve this unless someone else as a better idea?
Is there perhaps a cache that can be cleared on the tablet that reset stored Wifi networks or will a Kernal update help?
I'm new to Android so any advice would be much appreciated!
