You're awesome! Thanks again!!!We have a fastboot connection! As soon as i find what we need i will message you. When we are done i will post the chat to the forums.
The phone came unplugged from the computer. Is that going to matter for the next step? It's at fastboot processing commands again. Sorry darn dog!We have a fastboot connection! As soon as i find what we need i will message you. When we are done i will post the chat to the forums.
Did that and goes back to the download mode with the fastboot processing commands again.It won't matter none for now. Trying to find what we need. Just in case i'm downloading the .TOT file so i can extract what we need for it.
Since you said someone else was doing the steps earlier. Do you mind giving it a try?
1.Power Off the LG G3
2.Plug in a MicroUSB Cable into Your Computer
3.Press and Hold the Volume Up Button on the LG G3
4.Plug in a MicroUSB Cable While Still Holding the Volume Up Button
5.Wait Until You See a Firmware Update Screen
6.Let Go of the Volume Up Button
no problem.I posted the question with screenshots. I just like to be 100% sure before we move forward.
Any luck yet?no problem.
no problem.
Any luck yet?
Any luck yet?I posted the question with screenshots. I just like to be 100% sure before we move forward.
Thank you so much! I actually fell asleep before getting this and was worried I had missed you. Antime, I am home all dayAfter confirmation from @iowabowtech and valuable information regarding your device we are good to go.
Unfortunately it's late here 12:43 am and my eyes are burning from looking at my PC all day. I can reconnect via Teamviewer later today and help you fix the device.
You're welcome.Thanks a million James! Your help was amazing.
It was no problem. They put a new SIM card in it and it works fine. No chargeOuch
