help! desire dying??
melonbaps
Hi, my phone is running really bad, I have loads of space on phone storage but it keeps crashing. I tried a factory reset and settings hangs and asks me to force close! Is there another way to factory reset?
Taken from the HTC website.
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button..
Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.
Press VOLUME UP to start the factory reset.
Have you rooted the phone or is it straight out of the box,if it is out of the box I would get it replaced
