Help Help=device not compatible issue :(
nypdauxx
I am having device not compatible issue with my lg esteem. Is there anyway too get around the constant gameloft game messages and get the game to run anyway? i have seen many things like market enabler which didnt work for me, build.prop i havent tried and changing the lcd density( afraid to even try this not sure what number density too use it is stock 240 density) any help or ideas will greatly be appreciated. :(
open rom tool box and change lcd density to 240 and reboot the phone and you will be good.
when i open density modder it already says it is set on 240 as stock so im not sure what to do. if ind it pretty stupid that i use to run brothers in arms and gt racing academy on my lg optimus m but on the lg esteem which is clearly better i cannot. any ideas bro?
He doesn't mean that the play store says his device is not compatible. So its not an LCD density issue. Its the actual game or app, saying that.
And he needs to clear the cache and clear the data. This can be performed from the manage applications. Just scroll down to market/ or what is known as the play store . Some of us may have that 3312 still running ....
Again I don't think it has to do with the play store. If he downloaded them and they say his device is not compatible when he tries to run the game, than its nothing with the play store. Might have to edit build.prop.
yeah i get alot of errors using Gameloft games, there not support on the esteem, and some games require a dual core cpu to run some games.
