Help HELP devs with KERNEL
cool.gautam
Hey i tried porting a kernel but i get a error
"Amend Scripting(update-script) is no longer supported
Amend scripting was depracated by Google in android 1.5
It was necessary to remove it when upgrading to the ClockworkMod 3.0 Gingerbread based recovery.
Please switch to Edify Scripting to create working update zip packages"
helpp i know its gb kernel but it will work but can any1 tell me how to change scripting
You are using flashable zip. This zip contains script which is not supported by our recovery. Please share the zip which u r trying to flash. Someone will help you. You can directly flash kernel using fastboot.
And if it is a gingerbread kernel, chances are less that it will work.
It won't work even if you change the script... so until source is released leave the kernel..
A kernel can never be ported only Rom can be ported. BTW which kernel is this
