Help help??? did i make a brick?
ok so i got brave with my lg esteem from metro. i found a one click root program which worked perfectly. went thru and removed the bloatwear from metro being careful to only remove that which was known to be safe to remove. worked great. then i got real brave and flashed in the black plague extreme rom. everything went perfect. then i decided i didnt like it so i did a factory reset and now when the phone boots up it shows the lg stuff then goes into the boot/recovery screen of clockwork mods and i cant get it past there. tried reloading the black plague. no luck. found stock lg software to flash back in but no luck. any ideas to fix this would be much appreciated. i miss my esteem :( and before you ask yes i forgot to back anything up
