Help Help! Doesnt want a data plan
Kyla827
I just have a quick question. Im planning on getting a Fly touch 3 tablet with 3g but i only want to use the wifi not 3g. Do i still need a data plan?:confused: I really dont want one:eek:
Welcome to Android Forums, Kyla.
Just because the tablet has 3G doesn't mean you must use it. The catch might be if the tablet is subsidized by the carrier so to get it at a discounted price you may need to sign up for a data plan. If you buy the FlyTouch 3 retail, then I would assume that the 3G functionality just won't connect, because you have no approved network.
On GSM, if you don't put a SIM card in, you should be wifi only and no carrier involvement unless you are using a hot spot. I have no idea what CDMA does.
