xdroiduserx
when i click start to update, it asks me for spc code. what is it or how do i find it ??
You can go to android - whiterabbit.org to get your SPC after entering in your MEID into the converter.
You can get your MEID off the box from the phone OR it is located under the battery. Write it down, put it into the converter and your SPC will be in the box all the way to the right.
^^ what he said! Oh know did I leave that out of the guide
NOT LOL
in the LGNPST program click file-select dll-pick VS910.dll and click start again-enter spc
when i click file > select dll, nothing comes up in box, its empty.
Make sure you registered it-did you restart your cpu at all as the guide instructs you to?
i get this when i tried to register it - http://i42.tinypic.com/eg4kds.png
i also tried dragging it to "regsvr32" but the same message popped up.
Just pm'ed you...
You are running xp right?
no windows 7 .
That's basically the same procedure. The one I did just detailed it out more so.
http://db.tt/zcDmrfP3 = my guide.
Just got to work..give me a min..will answer your ?![]()
ok ill try again. btw am kinda confused , the instructions say get the vs910.dll because the ms910.dll was fake yet further down in the instructions it tells me :10. Grab the "MS910.dll" and put it in the "Models" folder.
11. Right Click "MS910.dll" and click on Install/Register. yet there is no "ms910.dll btw am using this guide because it seemed easier : How to Recover Your Esteem back to Stock - PlayfulDroidz Wiki . what em i missing here? this is confusing lol.
The vs910.DLL file is the one to register. Then once registered the lgnpst program will recognize it (file-select dll- vs910.dll Hope this helps![]()
ok. ill start from scratch & keep u posted.
Cool..ill be here uh working![]()
ive been following your tutorial & installing the files but when i get to skin.dll this pops up - http://i44.tinypic.com/m7a5l.png , an error message yet its on folder, do i proceed anyway or is there something wrong?
Did you disable user accounts control..?
Go ahead and unzip everything..continue with guide and when it comes time to open lgnpst let me know![]()
.FINALLY GOT IT TO WORK! i downgraded with no problems. thanks for your help, i appreciate it. IMO u should post ur tutorial on forum as its the easiest one, once again thanks for your help, i can finally ROOT.
