Help help. du battery saver ad
  • Start date Start date
yes it does have the option to uninstall updates
i clean my history by deleting data. i do it all the time
i noticed that this only happens when im connected to my wifi regardless of which phone i use, is this normal o_Oo_O
Not normal but I've definitely noticed things like this happening a lot more since Google banned play store apps from spamming users with out-of-app ads.
Hmm I don't get why it would be linked to your wifi... Does it happen no matter what site you're trying to access?
Imo Google should be banning devs who use these types of tactics to advertise their apps
it happened for the first time while i was on accuweather, the widget works but i can't see the full page, the ad will pop up right after the page loads. it also happens for some other sites
Ok, sorry, I'm away helping someone unbrick their phone.
Go to your phone storage - /sdcard will do
Find the Android folder, then below it, data.
Search for a folder there with something like com.google.android.chrome - or with the name browser in it.
Delete that folder.
That's where the highjack lives if it's that.
cant find that chrome folder, i did find an android browser folder though, and as i said earlier this happens in both chrome and in the browser
it stopped happening for some reason, the ad website is now a 520 error page
Go ahead and delete that one, if it's in Android/data.
Check out "Addons Detector"
https://play.google.com/store/apps/details?id=com.denper.addonsdetector
Another member with a similar problem found that helped him catch the culprit.
Press Scan, then after it's done, Add On to see if it finds anything. I've tested it myself.
dammit now it's on cpamobland.net
also, i deleted that folder, it only had one folder inside and that one was empty
great, now that same ad is leading into other porn/iphone 6/du speed booster ads
addons detector says no applications with addons
Hello, i have the same issue. When the "allow to run java scripts" is ON in the site settings, I get all the tithea "DU battery saver" ad on wwww.cpamobland.net. I have it on my galaxy S4 (android 4.4.2) and on my galaxy note 10.1. Did you manage to get rid off this ? Tx in advance
If it went away on its own and returned then odds are good that the ad agency supplying the ads has been hijacked.
Try using Firefox and then menu, tools, add-ons, and an ad blocker.
Hello: I'm from Argentina. Yesterday I bought a S4 mini, and while configuring it i found the same problem as xenomi an Fabrice G. Its as infected both my cell pones the s3 mini (old one) and the s4 mini. Doing some reserch in the web I found that some Italian guys have the same problem. Initialy I believe that was it because the s4 mini was originaly Italian, from Vodafone (imported here)
I've done everything on my old S3 mini, from simply wipping cache data to even flashing a clean stock rom (odin), and nothing changed. Now it is even worse, some other ad pages are popping up (adserver click, and other shit!!). Whenever i try to open a newspapper page for example (clarín.com or lanacion.com, pages with lots of flash and java) there pops DU battery saver. I ve tryied the stock internet explorer, chrome, CM browser, Firefox (with adblocker installed) and i cannot navigate. Have also tried disconecting from wifi, and conecting directly to 3g, and nothing.
Another thing, after flashing the stock rom with odin, with data wipping, ive restarted the s3 the with no sim card and only conected to my wifi router, without loggin on to anything, so no account connected, no Samsung account of google account. And, magic!!!!, DU battery saber cpamobland.net is there again. This is unbelievable, i dont understand.... Maybe the only thing left is a low level formating of the phones?? Or maybe setting them on fire (just kidding, phones here are very expensive, the s4 is something about 400 dollars)
If someone finds something please advise, i dont know what else to try
I have even written mails to the original duapps, owners of DU, and to Cheetah Mobile explaining the situation.
I dont now what to do anymore!!!! I dont even want to connect any other device to my
Thanks in advance
Dude I can fix it on my phone. This seem like bandit app permanantly make facebook and all brower app bad. So the way to fix is finding bandit app such as flash player , SNS and etc.. which highly installed out of play store. Let think of the last app it installed or upgrade before you found problem. Then restart the phone and remove all infected app the reinstall. You can try with one infected app to see wheter the bandit app is the one you remove or not. Good luck.
Hello: Thanks all for everything. I've found that my DSLrouter have been DNS hijacked, in the same way as 1 year ago. When I tried to get into the DSLrouter I could not log on, clearly someone had taken control of my admin password and the router. What I did was reset the router to factory settings, reconfigure with new SSID and password, reset both phones to factory settings and run a big scan in my computer (superantyspyware, malwarebytes, panda cloud, ccleaner, and manual removal of every local storage of chrome). Now the problem seems to have stopped...
Hope it works... and hope it is usefull to others!!!
Thanks
