monkeyboio288
Hello I currently have the lg optimus f3 through metro pcs. I love this phone but have been having software error issues. There are 3 issues. The first one is that the default galleries has "unexpectedly stopped" and does not work any more but this is not really an issue I just downloaded a different galleries app and have been using that (just would like to know why its not working). The second error has just recently began and same issue but with my contacts and it has "unexpectedly stopped". This is a bigger issue since I am not able to look at or even dial phone numbers for calls. I have been going to messaging and started a text and then hit the call from there to call people (very annoying and needs to be fixed but still not the main issue). The 3 and major issue is the "com.google.process.gapps has stopped working". This error pops up and once ok is clicked it pops up again a second after and does this like 15 times in a row before going away and then the phone is ok for a few minutes then happens again. This renders my phone unusable. (Very weird that you can get a click in on apps or the keyboard and run apps in between the error pop ups if ur fast enough). Looked this error up online and people say its super easy to fix just go to settings -> apps -> all -> app manager then disable and reenable. Or if that doesnt work under the all right shoulder button and reset app preferences. The first time I did this it worked for about 30 min and then same situation. I have done this over and over and it does not work. So I went with the factory reset. Seemed liked it worked and then boom same situation after half a day. Ive tried updating everything, Ive tried keeping everything default to factory reset level. I have factory reset 4 different times. My phone is not rooted and I have never rooted a phone but have looked at it to maybe do that but I do not understand any of the lingo or how to do it or if that is even the right thing to try next
. Please let me know of any suggestions or solutions. Please help and thank you!
If You Have Question Ask Me
