Help Help factory reset!
Is there any key pattern to factory reset the xperia play while its turned off. (ex- LG vortex you hold volume up and home key while turning on and factory resets it) I need to factory reset it
Not that I'm aware of buddy, the only way i know is to either (and im not sure) is to plug it into your pc/laptop and to do it through the pc suite, you can repair the os which does the same thing, the other way i know works for sure is to go into phone settings and do it from there.... hope this helps
