Help help finding adw launcher
You can download "AppBrain" from the market. Use the search function in AppBrain and type in "ADW.Launcher" and it should be the top of the list. If it won't load from from AppBrain app you should also download "Fast Web Installer". I can't remember if you need it or not for this.
Here is a link for AppBrain online if you already have AppBrain and Fast Web installer on your phone.
http://www.appbrain.com/app/adw-launcher/org.adw.launcher
you can type in "anderweb" he is the developer and click on any of his apps. then scroll down to "see more applications" and it will show you all of his apps, then there is a small list and you can find it there
