Help Help fixing buttons
peaxnut
Ok so I used the buttonremapper app to fix my volume down key that was stuck. Now the send, menu, back, end, volume up and down buttons dont work at all. I deleted the app thinking it would help but no luck. Any help would be greatley appreciated
WELCOME TO ANDROID FORUMS, PEAXNUT!
Which app is it exactly & who is the app developer?
I'm looking through the GOOGLE PLAY STORE & can't find an app by the name BUTTON REMAPPER.
Go to SETTINGS>LOCATION & SECURITY>DEVICE ADMINISTRATION>SELECT DEVICE ADMINISTRATORS> & remove the app that is affecting your control of the affected buttons.
Thank you for the welcome! Ok I dont see an option for device administration in settings>location and security? I should mention I have the ascend 1 not 2. I got the app by searching for "button remapper" on googlr and then download#d it from a forum I believe its thr first link that shows up.
