Root HELP flashing rom
essexgooner
Hi All,
I successfully rooted and installed a custom rom (leedroid) on my HTC HD then decided to clean all the rubbish from the back up folder in my file manager, but stupidly deleted the leedroid rom.
My screen went to the white htc screen then stayed there.
I managed to re install leedroid zip file to the sd card, removed then replaced the battery and installed the zip to the phone, but it says the install complete now flash.
I rebooted but I am back on the white screen again.
Can anyone help me please!!!!
Once the ROM is installed, it shouldn't matter if you delete the zip from the SD Card. If you can still get into recovery via the bootloader, you can try another ROM.
Did you take a backup before you installed LeeDroid or is that what was deleted? You could also restore that.
So sorry for not responding to your reply. I managed to get it sorted. In the end I flashed BlackICE rom and all was fine. Thanks again albeit late.; -)
