Help help for galaxy s2 att
rehsa
Hi there folks, I installed Ice Cream Sandwich on my S2 via ODIN. I had some problem and I restored. Now the problem is that the phone stopped receiving or making calls when i dail or receive a call i cant hear anything & the other party cant hear me
was it working before you restored? if so you restored something you didnt need to. else something probably went wrong with the modem, you can download those and flash through cwm unless youre on the stock kernel
When you say you restored, do you mean a factory reset? or did you reflash the update? This sounds like you may have flashed the wrong file.
I did the same thing with my phone and thought I would never get it back. You have probably done the same thing. When I flashed my S2 back to stock I used the international rom by mistake. Make sure you downloaded the correct rom for your phone and reflash it and you should be back in business.
