Help Help for installing new ROM
Hi guys im new to all this and appreciate any help..
I have already installed android 2.2 and everything seems to be working fine but i would like to try and install gingerbread..
This time should i just skip HSPL flash and Radio flashing, and go straight to flashing MAGLDR, then install the ROM???
If you have done hspl and radio already, just flash magldr and you're ready to install android in the nand.
Flashing ginger is the same as froyo.
if you want a clean install you should always use task29 when changing roms on hd2, specially if you're not updating the same rom. When you go thru different roms, a lot of them have different partition sizes so you'll have to change partitions, and to do that you need to reflash Clockworkmod, unless you have the new hd2 toolkit from xda and I haven't test it yet.
Hd2 flashing I know, so if you have the HSPL and the right radio(2.15.50.14 I recommend) then you task29/MGLDR 1.13/Clockworkmod with the necessary partition size/Flash desired rom, and you'll have a fresh install. :cool:
