derps
GPS stopped working!
(unending "Finding Location" prompt since Android 5.0.1)
Shortly after getting the Android update my GPS stopped working all together. I have tried everything i could think of. Uninstalled all recent apps, hard reboot, GPS testing app, full phone diagnostic apps, finally COMPLETE phone wipe re-installing everything. Nothing has worked! I am desperate. I use GPS all the time, not a single app, nor the phone itself can get the GPS to get a location fix. No matter what i do, the phone eternally says "Finding Location" for every single GPS using app, diagnostics or otherwise.
It is just a stock Verizon HTC One M8. A brand spanking new one, never dropped, stock verizon/android OS, like literally pristine new! Since the phone is not rooted i have no real way of rolling back to an older Android version correct? I noticed there was only one other post with the same exact symptons posted about 3 months ago that went without any answer/responses since. So... am i SOL? I tried initiating Verizon support on Twitter, but they think its a specific app problem... *sigh*
Any help is greatly appreciated!
(the above was also posted on the Verizon forums)
