E electroface Lurker Sep 8, 2010 #1 I tried to update my GT540, but the PC lose the connection with the phone. Now the phone can't exit Emergency Mode. Please, help!!!
R rikkib Newbie Sep 9, 2010 #2 Sounds like you didn't have all the correct drivers installed at the time you tried. Get LG Mobile Support Tool and install it. It should install all the drivers you need, then try again. Rikki Edit: if that doesn't work you could try "KDZ_FM_UPD"
M myil Newbie Sep 19, 2010 #3 i have the same problem. and i tried reinstalling the drivers but one of them always has a problem. help plz?
