This isn't going to be the easy answer you are hoping for, but I have to wonder about the state of your SD card. This is almost certainly a "hardware" problem, and the SD card is more susceptable to problems than the phone's interface to the SD card. If you did a factory reset, I would assume this was because your phone was acting flakey-- and it may have been acting flakey because of the SD card.
I'd start by taking out the SD card and making sure the contacts are clean and free of grease. I'd plug it into an SD card adapter and put it into a PC to see whether the PC can read it-- if it can, I'd back it up immediately in case the card is about to expire. Then I'd put it back into the phone and see whether the phone recognizes it. I've seen my Triumph do a little diagnostic on the SD card after startup-- there's a little icon in the notification area indicating that the SD card is being checked. From time to time I notice the SD card takes a while to "register" with the system, and the phone acts a little flakey while it reads the contents of the card and registers all the programs.
As for why Market doesn't recognize your phone, I hope you get some additional advice.
Regards...
make sure its in the phone completely, the cards clean, and the sdcard slot is clean... reboot the triumph with sdcard in it. and it should work
So what exactly were you doing when this happened?
LOL! I think I've tried that only 142 times today. Gave Up..Getting replacement from VM. THEN card should work All this because I couldn't leave good alone, and tried to install CMR. I don't know what I was thinking!.
The phones card reader may have gone out too. Call VM and get a new one under warranty
