Root Help! Half Bricked Phone
Leftie59
Using Titanium Backup Pro I deleted some ATT Bloteware and some backgrounds I did not think I was using.
When I turn on the phone it boot to the locked screen and I see the WiFi, 3G and Bluetooth connections. When I swipe to unlock the screen it is blank. When I hold down the up arrow (home) I get task manager to display. I can see all the packages installed and RAM usage but there is no Active Applications. Lastly I can answer a phone call.
Any Idea how I can restore the files I delete from the backup I made?
I my go through withdrawals with out my droid by my side.
Thanks
Well, you can begin by telling us what it is that you uninstalled. But in all likely you are just going to have to reflash the rom again. Not sure where one can get stock Captivate roms from. Search for it on Google. Don't try to flash Galaxy S roms on it.
