Root HELP!!! hard bricked one sv k2_cl computer reconigze the phone as Qualcomm HS-USB QDLoader 9008
unique818
i tried swapping the memory and it just never turn back on now computer reconigzes the phone as Qualcomm HS-USB QDLoader 9008 i need the correct files to flash them using qpst program but i dont know how to create those files that is the HEX and MBN if anybody wants to help me fixing this pls
What were you doing with your device when it got bricked?
unplug it from power source. pull the battery, put the battery back in,, hold volume- then press power button
the link I posted has a download tar.gz with
8960_msimage.mbn
MPRG8960.hex
GPP8960.hex
read all warnings though....
hmm...interesting... after replacing screen and glass on a one sv i bought for cheap and replacing main ribbon cable because of damage...
i also had the qhsusb dload issue going on... then i found drivers and it shows up same as yours...
my only problem is i haven't used qpst in so long...what all did you do to get yours to recognise device and such
idk i just opened qpst and i pushed add new port and my phone was showing up
