Help help help no power/unresponsive
Hi All,
Ok so I have run into a problem since January after having the phone for maybe 3 weeks.
I don't exactly remember how i managed to flash the phone but I did as it was getting updates from Samsung and not Google, so I just put on the Google image by holding down the power + volume buttons and did all that jazz. (Don't ask technical question about versions, etc coz i have no idea and I'm a bit of a n00b when it comes to stuff like that)
It was working for maybe a week but then the power button was becoming unresponsive. Could not turn on the phone. When plugged in via the charged the battery icon/charging icon appeared.
NOW, when I plug in to my PC WITHOUT the battery, it comes up in device manager with OMAP 4400 and is stuck on a loop, I manually installed the google driver and then it "ADB driver" keeps looping as well!
POWER + VOLUME combo doesn't work neither does USB connection then inserting battery, once the battery is inserted it just appears as though it's charging.
I have searched online and have NOT found any real solution except for sending it in to be replaced, but I bought it from eBay.
ANY SUGGESTIONS? WHAT'S DEAD? THE FIRMWARE/PHONE/BOOTLOADER?
Any way to reset the phone back to it's original form? Or some way without access bootloader as it's not working?
yes you can reflash the original ROM back, relock or re-root your phone (if you did all these). at the top of the forums there are 4 threads depending on your carrier and/or country that says ALL THINGS GALAXY NEXUS. go in there and they will have Reverse process steps to what you did
They all say stuff in regards to booting into the bootloader part, but I can't even get to that... I can't get to the bit where you use the commands :(
