okay so im having problems in running avatar on my samsung galaxy y. I have downloaded the data and saved it in a file named avatar in the file named gameloft. okay i turned on plane mode then i ran chainfir 3D pro 3.3 @nd on per app setting and for avatar i checked reduce quality to 16 bit and reduce texture then i clicked on powervr plugin.
and then i pressed launch button. it shows a zoomed in image of gameloft.logo then says please install data or something. basically i get an error messege and i cant play it. i tried uninstalling and reinstalling app and also clearing data from application management. it did run normally the first time i ran it but after closing it and trying to re open it the next day. it never worked. what should i do?? please help!
