You will not be able to access all the files on the phone, and probably don't need to. You can wait for root, but it could be a while/never for the Droid X.
What files/folders are you looking for specifically?
create folder called GBA. put in a rom.
i can play the gba game in the folder.
but when i disconnect and reconnect the folder is invisible.
but i can still see it through the phone
