Root Help how to put costum roms in i7500?
Remzo
Hello i have samsung i7500 i tryed to uptate new firmware and goasp costum roms but no sukcess i foolow instructions here on forum but odin not work with me i have win7 and on phone android 1.5 ,baseband version I7500XXIG1,Kernel version 2.6.27.exist any software for easy update rom and its free?tanks andvanced on help
It's going to be hard and I mean really hard. Cause Megaupload is down ages ago, we lost many files with it. There was a firmware version with a custom Recovery on it.
There is a another way a ahrder way, but you will need to use a guide from the sticky (DaSchmarotzer made it). Read it carefully and ask question before doing anything if you're not sure in what you're doing.
tanks on fast answer,i folow that quide but don work odin with win 7 my brake at half no connection :(too bed for megaupload hope that someone upload files somwhere else.
Does ADB work on your PC (do you have all the drivers needed)?
If yes there is a little workaround for it. By using ADB off-course.
