speedwheels
Kind Folks,
I have a T-Mobile Zte Zmax phone that hangs on the ZTE logo. I don't know how it got into this situation. I bought it like this thinking I can get it back to stock easily enough but now I realize that things may not be that simple.
Holding the volume key up/power and restarting the phone took me to the recovery menu. So I do have a working stock recovery. My question is this. Using the stock recovery, how does one go back to stock. i.e format all partitions install a clean copy of the stock rom? I have already tried a format cache/wipe/reset to stock from the stock, all to no avail. So, I download the stock rom.zip files some other folks had posted. Specifically the TMO_Z970V1.0.0B22_Stock-4.4.2.zip
So I copied this zip file to my sd-card and tried to install it from the stock-recovery(flash update from sdcard) but that process fails with an error "Signature Verification Failed".
I tried the same thing with adb sideload. The file would transfer correctly but the file would again fail signature verification. So I guess I have two questions really.
1. Does someone have a valid Zip file that I can flash from stock recovery to restore the phone image to stock?
2. If I cannot do this from stock recovery, how do I install a custom recovery using adb sideload (the only option I have available). I cannot boot into the OS since it hangs so all I have is ADB sideload to install a custom recovery. Does someone have a recovery.zip file that i can flash from stock recovery?
If not, what are my choices at this point? Any way out of this mess?
