Root Help htc desirs s no 3g
Hi all,
Ok so basically i had pacman rom on my htc desire s. Worked fine no issues just slugish. So i decide to find a faster slicker rom for my phone, I came across [ROM] | 04 Jun 2013 | AOSP | 4.2.2 | JellyFireBeanv2 Summer Edition
Installed fine.. Everything works APART FROM 3g, I go to settings mobile network and data connection is enabled.. I click APN and they seem to be turned on and correct for my network . (I AM ON 3 Mobile UK ) When i turn on mobile data the signal bars go from a blue colour to a grey colour. Then at the top I get a notification saying you have lost data connectivity because you left your home network? Ive tried reinstalling the rom several times. Ive tried turning aeroplane mode on and off. Ive even tried to put different roms and the same issue happens .Like i said worked perfectly well before on pacman rom.. Its not my sim card as tried it in my other halfs phone which i installed a pretty simular rom on and that worked. at first it said the same issue about data roaming but then decided after a minute to sort its life out... put it in my phone and even left it over nite ... nothing.... So something has happened whilst flashing JellyfirebeanV2 and i cant rectify it.. any ideas guys ...
I would definitely try to re-enter those APN settings and restart your device
Found them here:
Name – 3 Internet
APN - three.co.uk
Proxy, Port, Username, Password & Server - Please leave blank
MMSC - http://mms.um.three.co.uk:10021/mmsc
MMS PROXY - mms.three.co.uk
MMS Port - 8799
MCC - 234
MNC - 15
Authentication type - None
APN type - Internet & MMS (If no selection available , leave blank )
