Root HELP htc evo 4g problem
hnic5555
My HTC Evo 4g is on android version 2.3.5 but im trying to get it back to android version 2.2 by using the RUU what must i do my bootloader is already unlocked and i have root
You can't just downgrade your phone with a ruu.......a ruu can only upgrade the phone, not the other way around.
Are you rooted? If so you can just flash a 3.70 rom which is froyo or 2.2
I want to root it and use unrevoke because its easier to root and i need s off and I flashed a PC36IMG.zip through the bootloader on my old evo 4g and it took me back to the stock rom on 2.2
What is your hboot now?
Like I said a ruu or PC36IMG will not work by going backwards......they only work when they can update the phone.
