Can you please tell me what you did to fix the issue? I've been getting the Cyanogen boot screen and can't fix it. I've tried booting into clockworkmod recovery, doing wipes, hard reset, etc... nothing's worked!
Thread moved to the root section. If you could elaborate on how you fixed your issue, it may be beneficial for other people.
I have a few words of advice on themes. I would advise doing a Nandroid backup of your setup before you apply the theme. Themes have been known to cause issues when restoring Nandroid backups that contain them. Good luck.
