Help Help!! I accicedentally uninstalled google maps!!!
nonoapple
OK....so i was trying to update Google maps to the newer version because i kept getting an "unsuccessful" message. i followed droidforums and they said to uninstall it through titanium backup....now that i unistalled it still says the same thing when i try to re-download it/update from the market. does anyone have the original file for the Motodroid, or some way to get it back on or update it? :(
One possibility if nothing else would be to flash a recent backup of your ROM. That should restore you back to where you were with maps.
backing up now..**fingers crossed. if i do manage to get it back...would anyone now how to update it? to maps 5 or whatever the resent udpate was. i heard there was a way to do it through emulator...it had something to do with the permissions or something :/
here
http://androidforums.com/droid-all-...stall-google-maps-4-4-update.html#post1260323
i really don't get how to "type" it in...do i have to press enter after every line?
**updated: got it back
I was able to just install it through the market so don't know why it is giving you trouble.
You could try clearing data/cache on the maps app before trying to upgrade to see if that helps.
no cigar...it's weird because i have it on my Gingerbread rom. even the market updated on it's own.
I am not sure what else to try other than maybe trying to clear the market app's data and cache.
Also what ROM are you running? I think I remember reading some threads that said the new market app will not work right with certain ROMs. Just some thoughts.
voles-userbug 2.2 FRFxx 4953 test-keys
kernal: 2.6.32.9-P3droid
....nevermind, i just downloaded cyanogen, everythings up to date. thanks for help. everythings cool now
