If you got the app from Google Play using your mobile, install it there.when i try to install an app it says (in italian)that memory is full or that the application could not be installed in the default directory..
i wiped cache of google play app and of the phone,didn't work...
If you are at 10% left, then usually the low memory warning would come up. You either uninstall the apps or use Move2SD. Move2SD works only with an external microSD in the phone.
