stormcloud0217
It all started when my Droid 3 restarted out of nowhere. Then the text messages were backed up. It would say I had a message and then say I had never had a message. Then if i restarted it it would show a past message. After that it forced closed a lot of applications and would turn on and off. Also later on a message saying that the UIDs on the system are inconsistent, you need to wipe your data partition or your device will be unstable...which ends in a forced close loop. I tried factory resetting but aside from deleting pictures that did nothing. Then I put it in safe mode and it was the same minus the app force closes....but then it restarted to go back to the UID message. I've been confused for 4 and a half hours...so...someone help?
