help i want downgrade to 4.2
boogie85
Member
Hi any body knows how can i downgrade my nexus to
4.2.
Is not root, I want downgrade bez the touch is not work right
Please any help!!!!!
4.3 doesn't have touch issues that I know of. It may just be a bad installation. If that is your only issue with 4.3 i'd recommend a fresh install of 4.3 instead and if that doesn't work you can then revert to 4.2.
The buttons of home,back they not working and I was looking online and I'm not the only one with this issue after upgrade
And how do i flash it again Banished Angel?
Alternatively you can download a toolkit from here:
[NEXUS 4 TOOLKIT V2.0.0] Drivers, Backup, Unlock, Root, Recovery, Flash, Mods + MORE - xda-developers
Read through those links and if you still need help just say something.
