Buy Launcher Pro Plus (Plus = paid version). It's great! Download the free app, do a menu to upgrade to the paid app, put in the "key" number you get when you pay for it. Then, go back to Market, download the icon pack (free). When you open LP= and go through the settings, you will have options to use icons from the pack.
PS - There are lots of threads all about the LP+ and things you can do with it on lots of different forums. Check it out.
Luck!
