Help! In deep trouble :'(
I installed the malez recovery and after installation when i hold down "volume down", "camera" and "power button", it took me to screen with menus but now i am stuck. Every time i try to turn on my phone it takes me to that same screen. PLZ someone help me to get out of it!!!!
Weird.
On your dialer, enter *#*#4636#*#*
you will be taken to a Testing menu. Click on Phone Information. Scroll down and you will see a drop-down menu. On that menu, you will see the option for GSM Only (2G only) and WCDMA Only (3G only).
IF that fixes your problem, you can easily place a shortcut on your homescreen using an app like BetterCut or downloading TestingShortcut from the Market or even LauncherPro can do it (Long press-->Shortcut-->Activities-->Testing or something like that).
Let me know if that fixes your problem.
And flash a newer FroYo bin. The bin which you flashed was an unofficial release.
The leak might have bugs. Find one near the bottom of the list- Acer Liquid and Liquid E ALL ROMs bin extract collection - Android @ MoDaCo 4.008.08 is pretty much a vanilla 2.2.2 and 4.002.14 is probably the smoothest/most stable Acer ROM.
which do u recomend me to use? cuz am preety new at this
and is there anyway this will fix my 3g to turn off again? cuz when it was on 2.1 it was k but once i downloaded 2.2 it started acting like that
Weird.
i just tried it and it didnt work x.x
Wow that is really weird. Only thing which makes sense is that you have a defective unit. Which region was your phone from? Was it an A1 or a E? Maybe flash back to Eclair and send it in for warranty repair?
