Are you sure you have a compatible rom? What "Status 7" error means is that the rom contains an "assert" list to check against and your phone is not on the list. My guess is that the GT-i9100 is on the list but the "T" variant isn't.
From what I can see, the i9100T uses different modems, so if you flash a rom for the i9100, you can lose 3G until you flash the correct modem.
