Will research on EFS as well as check the IMEI, thanks!EFS backup is usually first thing I do but you had already started. When you get a chance pull your battery and look at sticker underneath. IMEI number listed should match what is in settings-aboutphone. If all is good you should only have to check APN settings and be back on the air
Thanks to all of you for the warm welcome and the help. Will probably be back often in seek of knowledge and information!Glad it all went (relatively) smoothly @amagras. You did the right thing... when in doubt ask!
I'm moving this topic to the Galaxy S3 sub-forum, as I'm certain it will be of help to other members contemplating the move to Cyanogen. You've probably helped more people than you realise by starting this thread... thank you.
