Root help installing hotmail on liberty
Are you using these settings?
Hotmail/MSN
incoming mail server: pop3.live.com
Security type = SSL
Server port 995
outgoing mail server: smtp.live.com
login required = yes
security type = TLS
Server port 587
did you access your pop3 settings in the Email app in your drawer?
you need to type in your email and password, then hit manual setup and hit pop3
and fill it out accordingly
Ok ill try that. I had to go back to stock so I could get my contacts fixed. Liberty doesn't have backup assistant so am of my contacts didn't show up
Ditch Backup Assistant for Google's cloud. Export your BA contacts from Verizon's website, while logged into Backup Assistant, as a .csv file. Log into your Gmail account on your computer and import the .csv file. Your contacts will automatically sync over to your device.
ill try that
hotmail supports push now, so you can setup as corporate email: Hotmail now supports push email, calendar, and contacts with Exchange ActiveSync
Server / URL
m.hotmail.com
Username
Enter full email address, for example: someone@example.com
Domain
Leave this blank
SSL
Enable this
Certificate
Accept the SSL certificate when prompted
where do i find where these options? when i selected pop3 it didnt give me these options.
i use K-9 Mail - Android app on AppBrain for my gmail and hotmail. maybe give it a try
i tried this and it did the same thing as the stock one
Hotmail/MSN
Security type = SSL
Server port 995
security type = TLS
Server port 587
how to get to the place to insert this?
Open K9, it should ask you to set up your email account the first time. Then it should ask if you want to let K9 set it up automatically or manually. Choose manual setup. Use the settings I provided.
If you somehow managed to get your email account setup already, but it's not working, then go to your account, press Menu, More, Settings, Account Settings. Enter the settings I provided under Fetching mail Settings, and Sending mail Settings.
