Root Help Installing Hydra Kernel
vandeec5
I am trying to install Hydra Kernel overclocking rom #1 (Hydra Kernels - Overclocked Kernels) But I keep getting this error when installing. The error is as follows
Finding update package...
Opening update package...
Verifying update package...
E:signature verficiation failed
Installation aborted.
Currently running Frankenrom Senseless
Hydra Kernel Stock Undervolt
Radio 2.15.00.07.28
I tried installing all four but no luck, kept getting the same error.
No prob, same thing happened with me trying to flash roms. Which hydra kernel did you use? Im thinking of overclocking but im not sure what the stability issues are like.
Where can we download the stock kernel in case you want to roll back?
Also, is installing kernels as simple as installing the ZIP from SD card in recovery mode?
radio 2.15
skyraider 2.5.2 vanilla
stock kernel..
I installed the overclocked hydrakernal #1 and it is just stuck at the boot screen. I know before i tried the hydrakernel it would keep rebooting. But this time it is just staying at the last boot screen image.. In the skyraider it is the eye with the red circles going back and forth.
It has been doing that for about 15 minutes now... what should i do? Wait till it does something, or pull the battery?
I read some where here that it is always a bad idea to pull the batter...
Please help..
Can someone explain to me the advantage in using a different kernel than the stock. I understand you get better performance, but the phone already runs great. Do you get better battery usage out of a different kernel?
