Root Help installing Req's Kernal....
Spikebob21
Help installing Req's Kernal.... title says it all i cant seem to get the kernal to install with out my phone getting stuck on the Android logo when booting...
i could really use some help...
Also i can't use Script manager its incompatible with my device... :(
what do i do?
EDIT: OK OK OK i read alittle more and it seem the kernel isn't going to work without cm7 installed along side it... i was only wanting the kernel not cm7 i use my phone too much cm7 is almost stable but not yet like the Beast... :P any comments let me know
what do i do?
What's the problem? Use odin to get CWM 5.0.2.7, flash his cwm 5.0.2.8, reboot recovery, wipe, flash stock++. If you're having issues with script manager, go to superuser and update the binary.
(and always make a backup)
