Root Help keep getting error
Keep getting process android. Media has stopped ... Camera amd gallery force close and can't use them
If you just flashed it could have been something that didnt "take" correctly in which case a fresh flash should fix it
If you have been running the rom for awhile and you have a nandroid i'd say try restoring from it and see if the issue is still there
also technically if you installed any apps they might cause it if there really not playing nice
I personally would just rewipe and flash, i ran the CM7-Reloaded for a few months and never had a issue with any force closes like that so something is not running right
