Root HELP - Keeps booting to ClockworkMod Recovery
andysousa
Hello all... I tried to put cog on my phone... I guess something went horribly wrong. My phone keeps booting to the clockworkmod recovery - voodoo lagfix screen. I have tried a few things to get past this but nothing works. Any help? I can't seem to mount the USB storage either... doesn't do anything. Am I screwed?
Try to get into Download Mode, use Odin to flash to stock, Master Clear using Odin OR GSM Master Reset with dialer key combo, and then retry the Cognition install process.
You might also want to re-read the installation instructions before you attempt to flash again.
