Root {HELP} LAuncher Apk WOnt WoRk
Playb0i
when i tried to change my font with rom toolbox, my phone rebooted and it was in a boot loop i did not put cwm on yet.:eek::eek::eek: and i tried the normal recovery and formatted the system data and cache but still did not work. and i also have admiral beast. it also goes straight to my home screen when it boots.
go into download mode and use Odin to flash the original files back...put the files found in the return to stock forum....you will add the ops file and it's either the PDA or phone...not sure brain fuzzy....late....
can i just flash them in cwm i just now put it on using odin right cause i really dont want to push with adb
they are tar files so you can't flash with Odin...they would have to be zip with updater scripts to work that way...
