Help HELP! Launcher Pro expired.
Cuda52774
My launcher pro expired. All I have is browser and can't switch back to touch wiz. My phone is essentially bricked unless all I want to do is surf the web. I may need to hard reset. Any help is appreciated!
Cuda
Expired?
Did you pay for the product? Do you still have the unlock code?
No. It was the beta. For those having the same problem, go to task manager, then package. Uninstall launcher pro. Default launcher should take over. Re install new launcher from market.
Cuda
my wife called with the same problem. she cant get back to any main screens. basiclly locked out. -she has a captivate btw...
update: says "It says to go to launchpro.com to get the latest version but it will not connect"
I found this on another forum and thought I would post here:
1. Use your search button and earch for "Settings"
2. From there open the settings application
3. Select "Applications"
4. Select "Managed Applications"
5. Select "LauncherPro"
6. Select "uninstall"
I walked my wife thru how to do this over the phone and she said it worked. Hope this helps.
