@liamorocks, go here:
[FAQ]GT540 Reference Thread ! - Android @ MoDaCo
Nothing to be concerned about.. Just read carefully, check the whole thread as there might be a solution you need...
@andrew.williams2010, Android update is not what Google handles.. It depends on the Manufacturer... Sometimes it even depends on carriers (The reason behind why Motorola DEXT/Quench wasn't updated to 2.1, I believe) I was going to buy A Quench lolz.. If you want better support, switch to HTC if you can, they try their best to update... One HTC Device just got 2.2 which has a little lower hardware than GT540... GT540's hardware can't handle Gingerbread... GT540 has everything to run FroYo, but it's processor is the problem... The processor (Armv6) can't handle Flash... All the devices can't get the latest update, because there hardware can't handle... Low-End devices are made cause not everyone can buy a device like Galaxy S or Nexus S... Believe it or not people in my country who are poor, still use Nokia 1100, and there are people also who can't buy a Nokia 1100...
Quench has better hardware than GT540, & it's stuck in ''Android 1.5''... LG's support is way better than Motorola... GT540's community is big & there are People who are making a 2.2 Custom ROM... LG Support of Australia has someone who tells you a little more inside info
So, I keep sending messages until he replies..
He told me that Android 2.2 will be tasted on GT540f... They will see if it's possible or not... So, there's a chance we might get 2.2 one day!
Don't take it seriously, I'm just trying to explain..
