Root help loading 2.15 radio
ohm911
i currently have the 2.05 radio now im tryign to load the 2.15 and i have read many thread about how to load the 2.15 but im still not getting it. i have downloaded the PB31IMG and put it root of my SD and boot the phone into hboot menu but it does not give me prompt to load the zip file. do i have to rename that to update.zip? also do i need the unrevoked forever to make this update work?
thank you
You need unrEVOked forever to set s-off, then you should be able to load it. Keep in mind at this time, unless it has changed recently, that will void your warranty as there is no current way to set it back to s-on.
