Root help loading a launcher pro icon pack
redchigh
I downloaded the icon pack to root, and unzipped it. (The zip file is still there too.)
I click on themes>icon pack, but the only option is "none". Isn't there supposed to be a 'custom' option?
Btw, I'm running bobzhome cm 7.2..
Thanks.
Where did you download the icon pack from?
Root of what? System or SD card?
I have launcher Pro plus unlocker.
Do you have a launcher pro folder on the SD card?
Launcher Pro made the folder when I choose to save the screen settings.
Please let me know more about this icon pack. If it's free, I'll download and figure out what needs to be done.
