Help HELP!! Locked out....
pacothebandit
So, I thought it would be beneficial to create a password on my phone. Not using the pattern lock I was going for something different. After MANY times of using the right password and knowing its right, It is not working. I am getting the 5 times wait 30 seconds message and i KNOW I am typing the right password. I am I effed? the phone is less then 30 days old and im really pissed off at the issues I have had with it.
Has anyone had this problem, and how can i reset the phone so I can start over. :mad::mad::mad::mad::mad::mad::mad::mad::mad::mad:
Download this program from this forum and do as it says. it will return your Nexus S/4G back to bone stock as it came out the box. I use it all the time when I return from MIUI roms. Quick and easy.
[ROM] Samsung stock D720 for Nexus S 4G - xda-developers
-Turn the phone off and simply take the battery out of the phone
-hold down the volume up and down buttons, then press and hold the power button and release the power button right before it vibrates while still holding the volume up and down buttons
-you will get a screen with a big yellow sign with an android on it
-plug the phone up usb and run the program software. let it do it's thing and your back to bone stock out the box
These instructions are provided by the program already.
