droidxlover
Sorry for the caps. I just updated my Droid X to 2.3 and now my Android marketplace is GONE! Help me get it back please!
I have the same issue.
I'm not sure, I did some reading. I am a complete illiterate when it comes to these android phones. I'm aware of what rooting is, and flashing roms and stuff..
But i wouldn't know how to do it. haha. I've tried just about everything I could.
I downloaded an APK vending file, That didnt work. I tried installing APP BRAIN, that obviously didn't work.
I don't want to root my phone or install a 2.1 rom on it, because I'd void the warranty.
I am going to speak to Motorola tomorrow, and hopefully they can help.
Sorry.
And yes, if anyone knows how to fix this, or has any better ideas. I'd(we) would appreciate it a lot.
you need the vending APK attached here http://rapidshare.com/files/424340338/Vending.apk
you will most likely need to use adb to push it to the phone.
That is like a foreign language to me hahah.
I'm still looking for a solution so far there aren't any. I'm attempting a reset.
it worked! my market is back. and all the apps i downloaded/paid i was able to install again, i backed up all my data so i have that there too. It's awesome.
It usually fixes most anything. Except dead pixels. And low ring tone volume.
Put this together into a little package, hopefully this helps someone else who has the same problem - worked for my fathers device which had the same problem.
Download, unzip, read the instructions, run the little script.
DroidX_Market_Fix.zip
hello all,
first post here but needed to let those having issues know what worked for me (droid x recently over the air update to froyo 2.2, which killed my android market). I will say i am phone newbie and was still able to do this in <15 minutes. I found the fix here:
(android market app disappeared on samsung galaxy s 2.2 update - android market help)
i will copy and paste for ease, and all credit goes to tomarppe. Important note: Make sure to follow the directions, regardless, on clearing old data at the bottom of this step-by-step guide to prevent force quits. Also i needed to power phone off and then back on after clearing data for new downloads and updates to work.
"to get the marked app back, without doing a hard reset.
Install a file manager like.estrongs or astro
to make it less complicated load the estrongs from here: downloading the file 1284764910_estrongs_file_explorer_1.4.5.apk ...
transfer it with e.g. Bluetooth or usb to your phone and install.
After installing the file manager.
1. Go to internal memory root
2. Navigate to /system/app
3. Locate vending.apk
4. Push on it to install it
it may force close the first time you run it but the second time it should work
if you still encounter force close or download issues. Do the following ( you might want to do it anyway as it is sometimes better to start with a clean slate)
1. Settings -> applications -> manage applications
2. Chose all
3. Find market
4. Push on it and select clear data
now it should work as advertised"
Same here! I actually did it earlier and saved our conversation and was about to attach it. TO ANY FUTURE READERS FACTOY RESET WILL RESOLVE THIS ISSUE!
Try following the procedures from this post:I have an LG optimus c and for some reason the market icon has disappeared. Is there some way of getting it back? how do i do a factory reset? Will resetting cause me to lose my data? Please help
Hello all,
First post here but needed to let those having issues know what worked for me (DROID X recently over the air update to Froyo 2.2, which killed my android market). I will say I am phone newbie and was still able to do this in <15 minutes. I found the fix here:
(Android Market app disappeared on Samsung Galaxy S 2.2 update - Android Market Help)
I will copy and paste for ease, and all credit goes to tomarppe. IMPORTANT NOTE: make sure to follow the directions, regardless, on clearing old data at the bottom of this step-by-step guide to prevent force quits. Also I needed to POWER PHONE OFF AND THEN BACK ON after clearing data for new downloads and updates to work.
"To get the Marked app back, without doing a hard reset.
Install a file manager like.Estrongs or Astro
To make it less complicated load the Estrongs from here: Downloading the file 1284764910_EStrongs_File_Explorer_1.4.5.apk ...
transfer it with e.g. bluetooth or USB to your phone and install.
After installing the FIle manager.
2. navigate to /system/app
3. Locate Vending.apk
4. push on it to install it
It may force close the first time you run it but the second time it should work
If you still encounter Force Close or download issues. Do the following ( you might want to do it anyway as it is sometimes better to start with a clean slate)
1. Settings -> Applications -> Manage Applications
2. Chose All
3. Find Market
4. Push on it and select Clear data
Now it should work as advertised"
